Ideas on engine stall -
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
1999 S70 GLT. Occasionally (3 times now over the course of approx 4 to 6 weeks) the engine will stall when I hit the brakes. I run in rush hour traffic every weekday 5 days per week
Times #1 and #2: cruising along in rush hour traffic at ~ 60 Mph and have to hit the brakes and slow down fast
Time #3 - this morning while sitting at a red light - light turns green everyone starts to accelerate (this again is a highway). I accelerate only to have the car ahead of me hit the brakes, I hit mine and it stalls. Now this is not a bury-the-nose-of-the-car type stop, more of a hard stop.
the car always starts back up, no issue.
there are 2 issues with my car I need to address - not sure either contributes or is a cause but still:
1) - i have a leak in the pipe going to the ETM i recently discovered during a smoke test which has not yet been addressed
2) - pretty sure the check valve on the fuel pump is bad. - plenty of fuel pressure, it just doesnt hold after i shut the car off
thoughts?
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
Has thanked: 1609 times
Been thanked: 4064 times
You need to have a nice tight induction path on a turbo me7 car (1999-on)
Get that snorkel leak fixed first
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Check the big accordion-type pipe going to the MAF sensor. Feel all around for cracks or even take it off and bend it.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
Has thanked: 311 times
Been thanked: 817 times
Eyeball that fuel pump sometime soon. Often "failing check valve" on a P80 is actually the hose inside the assembly is coming loose. Short, submersible fuel line hose between the electric pump and the top of the assembly.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Brake booster vacuum line or check valve?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
