Been thanked: 4065 times
I might be able to drag these back on a EU trip if interested. Do you know someone in EU you can ship to? You will have pay VAT if we pickup in EU
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
He can ship it to me, but I’m a bit out of the way from AMS.
1/2 a shitbox V70 1998 2.5 NA
Chieber
Post by Chieber »
Hello beautiful, came across this classic at a cash and carry.
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
abscate wrote: 14 Sep 2026, 08:59 I might be able to drag these back on a EU trip if interested. Do you know someone in EU you can ship to? You will have pay VAT if we pickup in EU
I propose my help if needed.
Manov.
Has thanked: 2200 times
Been thanked: 1852 times
Got a call from the 'boss' this afternoon. On her way home from golfing, the PITA 'R' just died on her. She called the AMA (AAA equivalent) and they turned up pretty quickly. The service member diagnosed that he felt the car was out of fuel. Strange as the car showed it had 20 liters in the tank. They added 5 liters of fuel and the car started up and ran. My wife went and filled the car but it only took 50 liters and then had the 5 liters the AMA guy put in. The car takes around 70-75 liters so it looks like the fuel gauge is correct.
It looks to me like it might be the ejector is not transferring fuel for some reason. Time to get the matches out and find a piece of bare land somewhere as I am not taking the tank out again. The car had a new pump and ejector, all new fuel lines which has the fuel pressure valve in it replaced about 10 years and maybe 5000 miles ago. Now lack of use is more likely the issue, but as to what is causing the issue. I will check if there are any codes but running out of fuel doesn't usually throw one. There was only one hose that I did not replace back then on the top of the tank which was not available even back then. It is 2 different diameters at each end (tapered). If that is the issue then the whole back end and tank have to come out. Time to fire up the camera an a cable and have a look for leaks.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Replaced the failing control arm in under 20min, I dont like how good I'm getting at it, too much practice :lol:
Bought a F.A.G control arm, it has a transparent balljoint cover, never seen that before :shock:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
scot850 wrote: 16 Sep 2026, 19:20 Got a call from the 'boss' this afternoon. On her way home from golfing, the PITA 'R' just died on her. She called the AMA (AAA equivalent) and they turned up pretty quickly. The service member diagnosed that he felt the car was out of fuel. Strange as the car showed it had 20 liters in the tank. They added 5 liters of fuel and the car started up and ran. My wife went and filled the car but it only took 50 liters and then had the 5 liters the AMA guy put in. The car takes around 70-75 liters so it looks like the fuel gauge is correct.
Oh, good grief.
The funny shaped hoses are all evap hoses, not fuel delivery hoses , so that won’t be the problem.
Could it be possible to detect the ejector transfer by feeling the crossover pipe with the fuel pump on?
Possibly. It clearly was able to transfer maybe 10-15 liters wither through 'slosh' over the top to the other side, or the ejector.
I think first thing is to check fuel pressure, not because of the pump, but see if there is a leak down of pressure (leak) or if the pressure is some how compromised getting to the LHS of the pump. When I did the rear end rebuild it included brand new fuel pipes and the fuel pressure valve, cross over pipes.
Thinking about what you said, if there was an EVAP issue, I would expect a P0440 /455 code. I was thinking more along the lines of not being able to build enough fuel return pressure to allow the transfer 'pump/valve' to do it's work. Fuel level sensors seem to be ok, and otherwise the car starts ad runs normally.
Now, were is that lighter...................
A fuel pressure measurement tells all.
FRom memory, the excess bleed from the FPR that sits on top of the AWD tank goes over to the ejector on the LHS, picks up fuel, and delivers it across the front of the tank to the RHS
If you have 50 psi at the rail you should be good , except for the edge case where the pump is dying, and only putting out 50 psi , with no flow to the ejector
I hope it is not the pump as it has maybe only done 5k miles and is one of the last Volvo OE pumps left at the time. Not using the car enough could be the bigger issue here, but the boss says we should sell one of our 3 cars and use it all year round and not put it away for the winter.
Now I just need to get enthusiasm to look at a car I hate working on.
