VADIS lists the cylinder head bolts (starting at the middle and working outward to the outer ones) at:
20Nm (14.75 lbs, ft), then
60Nm (44.25 lbs, ft), then
Angle-tighten another 130 degrees.
Good luck and let us know how it goes.
Timing belt broke. 99 S80 2.9
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Finally located the cam locking tool and set up the engine yesterday.
Anyone tell me the proper procedure to refill the cooling system? I tried to refill through the upper radiator hose and the fitting but there must be a correct way.
Thanks
Thanks
99 S80 2.9 / 99 Land Rover disco 1 / 86 Alfa Romeo Spider veloce
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Before starting make sure heater controls are on max heat.
Refill through the expansion tank, slowly, to avoid air locks. Also, from time to time, massage the radiator hoses to help dispel any air. When the system is full install the cap on the expansion tank and run the engine until the thermostat opens. Switch off and top up the system if necessary.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Thanks to all and this forum.
Yes it,s finally together and has been running like new.
Basically a new valve job because of a parted timing belt.
Now to see if any of the electrical problems rear there heads again.
Found a local shop that was willing to loan me the cam lock tool.
And the VADIS CDs from E-Bay
Tom
Tom
- billofdurham
Thank you for the update.
Here's to trouble free motoring.
Bill.
Bill.
Previously:
Previously:
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
From my VADIS:
Installing the cylinder head
Install a new cylinder head gasket.
Install the cylinder head. Use new screws.
Lubricate and install all the screws.
Tighten the screws in the order illustrated.
Tighten the screws in the following order:
1. 20 Nm.
2. 60 Nm.
3. Angle-tighten 130°. Use bevel protractor 951 2050 .
1. 20 Nm.
2. 60 Nm.
29 head torque.doc- Don't know if this will work. Tried pasting from VADIS to a .doc file.
- (1.04 MiB) Downloaded 474 times
Hi , My 1998 volvo v70 timing belt tensioner is broken. I was try to put new timing belt kit and I can not get those three timing mark where it suppose to be. After broken tensioner all three marks will not lineup. Your experties will be appreciated very much. Thanks...
- 12 Replies
- 2409 Views
Last post by precopster
- 1218 Views
Last post by lummert
