Hi, I recently bought a 1998 s70 T5 with 60000 miles.
Do I need to change the timing belt and the associated parts(hydraulic
tensioner, water pump/thermostat, aux belt/idler pulley/etc) at this
point?
Can somebody please give me the contact for any good volvo mechanic
in Edison/North Brunswick/Princeton (New Jersey) area?
I have noticed washer fluid leak today. Will it be expensive to repair. If I
can do it by myself, can somebody provide the details?
Thanks and Regards
questions from a new volvo owner Topic is solved
- Tsquared
- Year and Model: 11 C30
The service schedule for the T-belt is 70K miles on your car. I would highly recomend getting a Haynes manual. It list the recomended service schedule and processes to performa maintenance on your car. The $20 the manual cost will pay for itself with the first maintenance job you perform on your car.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
kenk
used to live in the edison area... there was a good shop in metuchen but the guy lost his lease, dunno where he moved.
not in the area anymore so i dont really know what to tell you, i think volvo of edison is okay. probably safe for a tbelt.
i think the consensus is the water pump should last probably up to 135k, same with the tensioner. The serpentine belt is not a bad idea its cheap, you should not need the tensioner on that or a new thermostat.
might not be a bad idea to get it taken care of now, the interval is 70k. but the volvos are valve benders if it breaks.
twobricks
In mid `98 model year Volvo switched from the reliable hydraulic tensioner to a mechanical one. The latter should be replaced on the first T-belt change. If it fails and the belt jumps tooth, the pistons slap the valves = $4500 repair.
Engine serial #1266127 and down have the hydraulic tensioner and engine #1266128 and above have the mechanical one. The engine serial number can be found on the front of the timing belt cover.
The best(and most reasonable) mechanic in Princeton area is Art's Garage. He has recently relocated to Ewing. He has been my mechanic for the last 10 years. The phone number is 609-530-1499.
As the responder above recommended get the timing belt checked ASAP. The $4500 cost for a new head is very real. It happened on my 93 850.
Volvo began installing wider belts in 1994, but the best advise is to do the maintenance.
- 15 Replies
- 2773 Views
Last post by V_T5
- 9 Replies
- 2248 Views
Last post by timfoley1
- 676 Views
Last post by aznatama
- 13 Replies
- 3749 Views
Last post by ashitaka695
- 44 Replies
- 6624 Views
Last post by brick_and_motor
