'94 940 CR 718 Radio Code
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
gc
Year and Model:
Post by gc »
My daughter recently bought a 1994 940 with the Volvo CR 718 radio installed.
Can't turn it on, get "Error" on the panel.
1. How do I find the code?
2. How do I enter the code?
Thanks
Harvey
Post by Harvey »
Your volvo main agent will supply codes for radios fitted when the car was new. You will need to provide them with logbook and proof that you own the vehicle.
Guest
Post by Guest »
You can calculate the code using the software: "CODE Calculator - Generator for some car radios
v2.12.51.63"
I did it with mine - works perfect!
You have to open the radio, locate the 12 diodes on the PCB and measure which of them are present and which - not. These are the 12 bits that the on-board CPU uses to calculate your radio code.
The radio is EXCELLENT! I replaced my older unit with CR-718 and the change in the sound quality is Amazing!
S.
