help Water leakage s60 2.4t
b0radhamilton
Year and Model:
Post by b0radhamilton »
I have water coming from the back of my motor. HELP!!! I have no clue how to fix it or what the problem is.
brad hamilton
2001 Volvo s60 2.4t
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
Water? How do you know it's water? Antifreeze, maybe, but water?
Also, specifically from where? Back of engine is a bit vague.
We'll try to help- just tell us more.
b0radhamilton
Year and Model:
The previous owner took bad care of it I picked it up very cheap. Looks like it could be a freeze plug or a head gasket but I just don't know what to do. Whatever it is, water or antifreeze, its leaking from behind the exhaust manifold. Im planning on taking the exhaust manifold off. Good idea or no?
brad hamilton
2001 Volvo s60 2.4t
MadeInJapan
No, I wouldn't do that...most likely it's not coming from within the manifold...you'll do all of that work just to find that out. See if you can use a paper towel and dab it up... does it have color? If so, what color? The reason I ask is because there is a coolant line back there and I'm thinking that it is leaking- in that case color would be slightly green.
b0radhamilton
Year and Model:
ok cool i will give that a try first thing and get back to u. thank u
brad hamilton
2001 Volvo s60 2.4t
b0radhamilton
Year and Model:
ok now it wont start it sounds like its not getting any gas but it is.and the water is still coming from the middle of the back of the motor right next to the turbo and it is the water from the radiator, so what do u think
brad hamilton
2001 Volvo s60 2.4t
MadeInJapan
Don't drive it. How much is missing from your expansion tank?
Definitely the coolant hose. You need to get it fixed.
b0radhamilton
Year and Model:
how could i remove it so i can fix it or get a new one
brad hamilton
2001 Volvo s60 2.4t
MadeInJapan
I suspect that #15 gasket is bad and needs replacing and retightening. The part number is located in the right pane of the diagram below. Not sure of the tighening torques and you need to make sure this is the correct place of the leak. If not #15 then 0-ring #16 might be the culprit.
S60 turbo Coolant lines.jpg (138.95 KiB) Viewed 1107 times
b0radhamilton
Year and Model:
dont think that is it
http://i472.photobucket.com/albums/rr89 ... age045.jpg
no the water is poring out from behind the manifold even when its not cranking and i cant seem to see it. something tells me its a head gasket but there is no oil in it. and no water in the oil what do you think
ps: thanks for all the help so far
brad hamilton
2001 Volvo s60 2.4t
