New Modified Transmission Flush Method with Pictures
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Without knowing more about it, I would have to agree.
wolfspiritky
- Year and Model:
The pink color also make pancakes and waffles much prettier too!!!MadeInJapan wrote:Tell them you drink oil for breakfast
00 S80 T6
97 850R
94 850 GLT-Totaled!
97 850R
94 850 GLT-Totaled!
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
Thanks for the info on the oi. FWIW I did a drain/refill with Castrol Domestic Dex III ATF which according to it's spec sheet meets IIE specs and it f***ed up my tranny again. It is back to doing what it did prior to my first drain/refill with Wal-Mart fluid. I promptly did another drain/refill with Wal-Mart Supertech and it has eased a bit but I'm sticking with the Wal-Mart brand for now. FWIW my car drops out of gear when coming to a stop when hot. The first two drain/refills completely fixed it but putting Castrol in there made it do it again.instarx wrote:Be very careful about any automotive fluids you buy at Wal-Mart. There is a reason supertech ATF is $2.20 per quart and not $10 -- and it isn't because Wal-mart is such a good negotiator. Although much of it looks name-brand it is often special order Wal-mart stuff. For example, Wal-mart sells "ExxonMobil SuperTech 5W-40" motor oil that is a very low-quality base oil with very few additives (source: Bob's The Oil Guy). You can't buy that oil anywhere but at Wal-mart even though it looks like a genuine national Exxon brand.wheelsup wrote:The "regulars" on here are going to cringe but I used the wal-mart special "Supertech" 4-qt. $9 jug for my drain/refills. I
I don't know this for a fact, but I suspect that "Supertech" is the wal-mart house label that is always formulated to sell at the lowest possible price.
If you buy oil there make sure the label is exactly the same as an oil you can buy somewhere else, like at an Autozone. If you can't find "Supertech" transmission fluid anywhere but at Wal-mart you are taking a big risk in my opinion. This isn't a rant on Wal-mart - just a fact.
1995 850 GLT Wagon w/ 200,000 miles
well matt, nobody else is going to do it, so i'll go ahead and give you the bad news. If you've got 145K....It aint the oil my friend. Start saving your money, and start looking now at eirie vovo or volvo and saab dismantlers for a wrecked car with a rebuilt or low mile tranny. The end is near.
wheelsup
- Year and Model:
Yep I know, although it's been doing it for 3 years/30,000 miles so I'm just waiting till it blows
. Can you use a Saab AW50-42LE tranny on our cars? I've found a lot lower mileage trannys off of the 9-3 and 9-5 cars because they are younger (98-02 model years I believe).
It did completely go away when I used Supertech fluid so I'm hopeful that doing some more drain/refills with it to get that Castrol out of there will fix it...for now.
MadeInJapan
Use the supertech flush again and see what happens (it worked once, right?) I do agree though that most likely it's on its way out.
wheelsup
- Year and Model:
I'd love to do a flush, I'm just scared to take my hoses off the radiator...
So I just settle for drain/refills. Actually the one on the bottom is fine, it looks normal, it's just this top one that is rusted.
MadeInJapan
...and that's the one you need to remove
I guess I would be tempted to just do the drain and fill myself too, especially if I didn't want to fool with things. That said, if I had a whole day to devote to this and had spare parts available, I would probably risk it and take it off...most likely it's just the outside that's rusted. The ATF in and of itself would keep the inside clean.
gshadow325
- Year and Model:
For a second there i thought you had a 99+ car with a ETM problemwheelsup wrote: FWIW my car drops out of gear when coming to a stop when hot.
btw-gotta love MVS, 2 year old threads don't die hahaha
1998 Olive Green V70 T5 Manual - 155k Awesome car
2003 Nautic Blue XC90 T6 3rd tranny - 162k Modded
2001 Nautic Blue C70 T5 Manual - 92k Not stock at all
confused_al
- Year and Model: 1996 TLA wagon
Its not as bad as it looks. You might need to brush off the rust and clean it before you take the hose off.wheelsup wrote:I'd love to do a flush, I'm just scared to take my hoses off the radiator...
This is mine after flush.
- IMG_0377.JPG (37.45 KiB) Viewed 3091 times
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- 9 Replies
- 2995 Views
Last post by Pezgoon
- 1581 Views
Last post by Turbo_Boss
- 1294 Views
Last post by matthew1
- 14 Replies
- 4975 Views
Last post by firstv70volvo
- 1649 Views
Last post by MoVolvos
