Oil Spray
toddv850glt
- Year and Model: '95 850 GLT
I just Did the 95 850 n/turbo flame trap and oil seperator project. Take your time with the project and clean everything. I would for one use a 1/4 drive swivel socket with a long extention for the intake bolts, adapter for 3/8 if you need to torque the bolt, and I would take off the steering pump and alternator for ease to loosen and torque down intake bolts. I also had Napa auto do a chemical dip for the intake (what a difference) and took the throttle body off to thoroughly clean it. Change the lower radiator hose now if you dont know when it was replaced, its just hard to get to. I prefer to use eEuroparts.com for the goods
'95 Volvo 850 Glt N/A 5spd.
'96 Pontiac Grand Am
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
This is from VADIS. On your model, the nipple was replaced with a "cover." Still, you need to make sure the airway from the intake (accordion hose) to this "cover" is well cleaned out. Use stiff pipe cleaners and alcohol to make sure there's no build up in the passage way.
MadeInJapan
If you want, you can order the 0-rings and spacers found here: http://www.fcpgroton.com/category-exec/ ... by_year/48 Use Vaseline (yes, Vaseline) on these before reinserting your injectors. Conversely, you can detach the fuel rail and take the intake off with the injectors still in place and won't have to pull them out- the method used is whichever you're comfortable with.
- 3416 Views
Last post by rspi
- 638 Views
Last post by alexk243
- 1918 Views
Last post by RussB
- 39 Replies
- 6184 Views
Last post by DanelleNavarro
- 20 Replies
- 3759 Views
Last post by erikv11
