2001 S40 has the check engine light on
2001 S40 has the check engine light on and the following codes P101, PO171,PO200,PO301 and PO130
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Welcome to MVS.
I do not find a P101...there's a number missing in there.
P0171: Long term fuel trim, upper limit.
P0200: most likely a signal fault with cylinder #1
P0301: misfire code
P0130: 02 circuit malfunction for front 02 sensor
Can you give us a little more information regarding what kind of maintenance, recent work, etc. your car has had? All point to something possibly electrical or some type of vacuum leak or possibly a fault with the MAF sensor.
P0301: misfire code
MadeInJapan
I would reset the codes and see if they come back. Sometimes dealers don't reset things after they work on our cars.
MadeInJapan
Use of a scan tool or you could disconnect your battery for a few minutes (make sure you have your radio code).
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Your first code, P101, is probably P0101 which is the MAF/VAF sensor range possibly caused by an intake leak. This would cause misfiring on increased acceleration.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
I spray water on the intake manifold joint with the engine idling and if the engine starts to die there is a leak.
Others spray carb cleaner and if the engine surges there is a leak.
Both work but the water is cheaper.
Bill.
Bill.
Previously:
Previously:
