850 Turbo wagon 1996 Massive gas leak
pt850
Year and Model:
Post by pt850 »
First, thanks to the posters who directed me last week to the odometer fix thread. I haven't yet addressed that, and another more urgent issue has arisen. When filling the gas tank, if I allow the gas to flow until it automatically shuts off, I get a huge leakage of gas on the pavement. If I add gas without letting it fill completely, it does not leak, suggesting that I have a leak in the tube leading from the filler cap to the gas tank.
Is this a common problem? Is there something I can look for before heading to a repair shop?
Many thanks.
pt850
turbotim2
Year and Model:
Post by turbotim2 »
You'll have to crawl under there and check the filler hose from the neck to the tank. I can't say if its common but I don't recall seeing any threads to that regard.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
summit3000
Year and Model:
Post by summit3000 »
I had this issue. What it ended up being was the sender pump was not screwed on completely (cross threaded) and so it leaked out that. When you look at it you should be able to tell where the fuel is leaking from and that should help in tracking it.
Delboy3867
Year and Model:
Post by Delboy3867 »
I had the same issue and yes, like the earlier poster, my fuel pump had been poorly seated after an earlier replacement. Worse yet, on a full tank there was a strong petrol smell in the passenger compartment. After removing and re-seating the pump, the issue vanished. The threads appear to be quite fine and prone to cross-threading.
pt850
Year and Model:
Post by pt850 »
Thanks Summit and Delboy for the info. I'm pretty sure you've hit the right answer, as I had my fuel pump (insert) replaced only a couple of months ago. I will give it a shot. Do I remember correctly that there is a gasket under the fuel pump retaining ring? Do you recommend replacing this gasket when reseating the pump? I don't think the indie mechanic who replaced the insert replaced any gaskets (which may be why it is leaking!) Again, thanks.
Delboy3867
Year and Model:
My gasket wasn't so badly shaped when I re-seated the pump so I just re-used it and it's holding fine. As with most gaskets, I would recommend replacement if you've got the thing apart and have access to a new one for sure.
pt850
Year and Model:
Post by pt850 »
So, I took the car back to the shop that had replaced the fuel pump insert. They replaced the gasket & reseated the cap, and I drove to a nearby gas station. Filled it to the brim and -- no more leak. Thanks, guys!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
It's always nice to read of a happy ending- now, on to the odometer gear!
