Hi
has anyone a link to removing the drivers door panel ?
A gust of wind caught my door and damaged the Check strap which now need replacing.
It gets very windy in Ireland
Thank you
John
Drivers door panel removal XC90
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
This is the VADIS instruction:
The warning about the battery lead - After switching off the ignition wait at least 5 minutes before disconnecting the negative battery lead. This is to avoid problems with SRS.
When re-connecting the negative lead the ignition switch must be in position 2 and nobody should be inside the car.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
Looking at the parts list there are 9 clips.
I should also have added that after re-connecting the battery you will need to initialize the upper electronic module which controls the central locking, interior lighting and sun roof if fitted. This is done by unlocking the car using the remote control or a key. Really difficult step, that one.
If your car is fitted with the manual or standard climate control you will also need to calibrate the blower fan. If fitted with a sun roof this will also need calibrating. Let me know if you need the instructions for either or both of these.
Bill.
Bill.
Previously:
Previously:
cdnvolvo
- Year and Model: 2006 XC90, 2001 V70
Could you pls add those extra instructions for the climate control and sunroof too pls? Seems like disconnecting the battery is likely at some point. Calibrating a sunroof??? Geez. Thanks in advance !billofdurham wrote:Looking at the parts list there are 9 clips.
I should also have added that after re-connecting the battery you will need to initialize the upper electronic module which controls the central locking, interior lighting and sun roof if fitted. This is done by unlocking the car using the remote control or a key. Really difficult step, that one.![]()
Bill.
- billofdurham
Instructions attached.
As has been said on this site recently, "There are too many computers on cars today." However, it does not change the old saying, "The biggest nut is the one behind the steering wheel!"
Bill
Bill
Previously:
Previously:
Hi Bill,billofdurham wrote:Instructions attached.
As has been said on this site recently, "There are too many computers on cars today." However, it does not change the old saying, "The biggest nut is the one behind the steering wheel!"![]()
Bill
Do you have the instruction on removing the rear right side door panel for 2006 XC90? I'm trying to fix the power window issue with my XC90 and need to have a look at the how the power window mechanism works and what broke. Thanks.
- 2594 Views
Last post by jonesg
- 1221 Views
Last post by halseyfolk
- 1848 Views
Last post by VolvoChef
- 960 Views
Last post by chefmarkt69
- 430 Views
Last post by wackenhut
