93 850 NT not starting help!
james78
Year and Model:
Post by james78 »
These are my symptoms. Engine rotates over, has spark, has good fuel pressure. Will not fire. Crankshaft trigger was replaced about 2 years ago. Has good compression. Computer codes say intermittent crankshaft trigger signal, and MAF sensor signal absent or faulty. I wanted to check the Camshaft position, and according the the haynes manual should have 12 volts on pin #1, and between 1 and 5 volts on the other two. There is no 12 volts on pin 1. I was wondering if this sounds like the computer to anyone else. This really sucks because me and this car have come a long way to include chipped exhaust valve and head gasket. Does anyone have schematics for the computers. I have worked on electronics repair for 9+ years down to component and it seems to me like the computer supplies the batter voltage to the hall effect trigger which should vary it between 5 and 0 volts. Does anyone know where to get a computer relatively cheap for a 93 850 non-turbo?
93 850 GLT
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
It tells you nothing about the firmware and you need to be very patient on the download. The server is in Poland but the schematics are in English.
http://pliki.mojevolvo.pl/volvotechinfo ... n_3_39.pdf
These schematics are more user friendly but less precise:
http://www.savefile.com/files/2001813
