95 850, N/A, 201K
Tachometer stopped working, just sits there at zero. Car seems to be running fine otherwise, except maybe the speedometer is reading a little bit high. I say maybe because I haven't tested it (I was thinking of just having a friend drive ahead of me at a steady speed and see if I matched) and I'd be entirely willing to believe that I'm just gaslighting myself on that one.
Anyways, anyone seen this before? Is a new instrument cluster in my future, or maybe just a sensor?
thanks
kd
95 850 - dead Tachometer, wonky speedometer
kiddynamite
- Year and Model:
- misha
- Has thanked: 152 times
- Been thanked: 402 times
You don't need to replace instrument cluster,just odometer gear.It's common problem on 850's.Here is explanation how to do it yourself: https://www.matthewsvolvosite.com/2005/0 ... ix-how-to/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
kiddynamite
- Year and Model:
The odometer turns fine right now; it's really just the tachometer (RPM gauge) that has failed.
- misha
Sorry,
Check rpm sensor for loose connection.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 75 times
There are self test diagnostics you can do on the cluster through port A-7.
Download the service manual pinned at the top of the page - https://www.matthewsvolvosite.com/forums ... =1&t=18706 - and then see the file named instrument panel.pdf for the procedure. If the instrument cluster passes the test look to a wiring problem or the vehicle speed sensor that Misha referenced. Normally when the VSS fails it throws a bunch of engine and transmission codes.
- 623 Views
Last post by deedatc
- 855 Views
Last post by wizechatmgr
