S80 2000 To start of not to start
kmohnike
Year and Model: 2000 S80
Post by kmohnike »
We've changed the battery, starter, alternator, ingition switch; checked/cleaned the battery cables and ground connections, but the car still continues to have a problem starting with the same symptoms: clicking noise--almost sounding like a drained battery except it will start after cranking it 10 or so times...
Any ideas?
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
How many miles on the car? Turbo or not? When were the spark plugs last changed? Fuel filter? Timing belt?
kmohnike
Post by kmohnike »
134,000; all tune-up work and timing belt changed about 20K ago--It's not a turbo. :roll:
fs
Year and Model:
Post by fs »
Ó
vegasjetskier
kmohnike wrote:134,000; all tune-up work and timing belt changed about 20K ago--It's not a turbo. :roll:
Did you reuse the old solenoid on the new starter motor?
vegasjetskier
Does your relay/fuse block in the engine compartment look like this?
99volvo4life
Year and Model: 1999 volvo s80
Post by 99volvo4life »
i have this same problam can u tell me whats wrong
lev
Year and Model: 1999 S80
Post by lev »
I would guess that you have a bad starter or least the soleniod is bad. Check all connections.
Make sure the replacement battery is the right size and has the right cranking amps. I have had problems with the battery size being incorrect.
balah26
Year and Model: sedan,s80 2.9l 2000
Post by balah26 »
Have the same problem and i just fix it, these is how;-
[1]check or change your fly-wheel bcos once there is a crack or dent the contact with the ignition would be failing and starting would be hard. [the starting problem would be over.] pls try it is100% guarantee.
