towing 740 w/automatic trans
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ccb222
Year and Model:
Post by ccb222 »
I just read chapwest post re: towing a car w/manual trans. I've been told I can tow my '87 740 wagon 4 down IF I disconnect the drive shaft at the rear differential. Since I'm relocating, this is a one-time thing and the trip is 1500 miles so dropping the drive shaft is not a hassle if it's an acceptable thing to do. If it's OK, do I also disable the steering OR let it find its own way? Thanks, CCB222
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
ccb222 wrote:. . . do I also disable the steering OR let it find its own way? Thanks, CCB222
You have to put the key in the ignition and unlock the column and leave it that way while you are towing. The tires will then track around turns by themselves. DO NOT back up with the car connected to your tow vehicle or you may do significant suspension damage!
ccb222
Year and Model:
Post by ccb222 »
Thanks, vegasjetskier, for the steering info. Since you didn't mention it, I assume dropping the drive-shaft is the right thing to do. Thanks again. ccb222
vegasjetskier
ccb222 wrote:I assume dropping the drive-shaft is the right thing to do. Thanks again. ccb222
I can't advise on that. I'd check with Volvo to make sure it's OK.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The advice from Volvo on towing auto 740s is:
They must not be towed more than 20 miles (30km) nor faster than 12mph (20km/h). If these conditions cannot be met, or if transmission damage has already occurred, the propellor shaft must be removed or the vehicle towed with its rear wheels off the ground.
You must remove the shaft completely, not just at the diff.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
ccb222
Year and Model:
Post by ccb222 »
Thanks, Bill, I'll remove the shaft and head up the road. However, I'd like to repair the problem with the car first, and if you have any ideas re: my post (ccb222) of June 15, I'm all ears. Thanks again, ccb222
