Having two problems with the A/C. First the A/C air temperature does not cool off. Just had the A/C serviced. The low side fill valve was replaced, the valve core serviced, and R134 refrigerant added. Still blows barely cool air. Second, the passenger side air comes out warmer than the drivers side.
Also of note, when the recirculate is engaged it does not get incrementally cooler as would be expected, it seems to make no difference.
Any ideas of where to start in diagnosing would be appreciated.
2001 xc70 Air Conditioning Problems
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
I would guess that you either have a bad Climate Control Module or you have a couple damper motors out.
- 665 Views
Last post by 2006XC90user
- 1785 Views
Last post by mick_jenkins
