242 R sport Dash connection
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
hrforever
Year and Model:
Post by hrforever »
I've had the above dash since Dec last year and have finally gotten around to putting it in. I thought it was a simple change over but all that's happened is it blows the power fuse when the ignition is turned on.
The Volt and Oil gauges run ok by themselves with their own wiring but I cannot guess what the cause of the problem is. Is there extra wiring needed as there are 4 pins (2 above and 2 below) near the half moon plug that are not connected with any original 242 wiring. I've put in another power regulator thingy but no change, just another blown fuse, and if I put the original dash back in everything works fine.
Anyone got one of these dash's and had similar problems, or know of a fix? This is very frustrating.
