Sounds like marbles rolling around in the oil pan
Disney_Volvo
- Year and Model: 850 GLT 1997
While doing some routine maintenance on my 1997 850 GLT (about 200K miles), I noticed that it sounded like there were marbles or rocks rolling around in or near the oil pan. Could that be a sign of eminent oil pump failure? Is there anything I can do to troubleshoot the oil pump?
- Year and Model: Many Volvos
- Been thanked: 76 times
You are not being ignored but I have never heard of such a condition. Are you sure that you are not hearing a bearing on the AC compressor or something like that.
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
This is an interesting sound if wasn't just a one time sound.
How does the car run? Have you had major problems before? I would think it's something rolling around in the oil pan, but normally you'll only get little metal shards that you wouldn't hear.
Interesting... keep us posted.
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
It could be that your main or rod bearings are worn out. Does your oil pressure light come on? Has the engine been run before with no oil pressure?
Lutley5060
- Year and Model: S70 1999
A bad catylitic converter can make the marble sound.
Welcome to MVS,A bad [sic] catalytic converter can make the marble sound.
You are so right, my wife's Jeep Cherokee detonated a cat and it sounded like a gravel pit on wheels. It will rattle without the engine running if you just tap on it.
- 9 Replies
- 1906 Views
Last post by Georgeandkira
- 774 Views
- 818 Views
Last post by Sommerfeldt
- 1199 Views
Last post by polskamafia mjl
- 1626 Views
Last post by kcodyjr
