850 exhaust question
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
code-man850
Year and Model: 855T '96
Post by code-man850 »
I'm looking at buying an OBX turbo back exhaust for my 855. By looking at the picture of it, it doesn't seen to have a cattalytic converter on it. Correct me if i'm wrong. And if it doesn't have one is it easy to plug one in if I bought one and took it to the guy that will be installing the exhaust?
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I'm not sure of your answer, but since you live in California, the fairly cheap CATS are now out as Calif. just upped their laws and restrictions- make sure and check out what you can even buy and put in your car now. I believe it's even against the law to sell and ship a CAT to Calif that was acceptable a month or so ago (from what I've read). Good luck and post back your experience and what you end up doing.
code-man850
Wow. Thanks a lot. The "newly approved by California" catalytic converters are selling for around $220. Doesn't make the exhaust such a deal anymore. Here's a pic of the exhaust.
'96 855 Turbo
K&N, H&R, Mobile 1
csbrianp
Year and Model:
Post by csbrianp »
I saved myself a bunch of money by building a cat back exhaust using a local muffler shop for my 96 850R. I purchased a Turbo Muffler from Pep Boys for about $20, and had the muffler shop cut the stock muffer out and welded in a 2 1/2" pipe out the back.
2 things happened, My car immediately became a terrible car to drive. No get up and go. The other was the noise, I know that's why you add a performance exhaust but it became too loud. My wife won't drive it any more. My son says it sounds cool when idling, but even he doesn't like the droan at freeway speeds.
I fixed the drive ability by advancing the exhaust cam 2 degrees.
So, when you read about guys putting 3" exhaust on their 850 turbos it might make more power in the higher rpms but I guarantee it will be as slow as a non turbo in daily driving.
Bian
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I was thinking of getting a full exhaust done on my 850 T-5. But after reading this, I am having second thoughts. Would a cat back exhaust do this? Would it be worth running a cat back or should I stay with the stock exhaust?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Many have done cat-back exhausts... the trick is to buy what's worked for everyone (IPD exhaust kit, for instance).
If the setup gets too free-flowing like csbrianp's you need to mess with your cams's timing because the stock engine depends on a stock amount of backpressure to work right.
I don't know how the kits get around this, or if they just go right up to the point where you need to adjust timing.
Also -> Amazon link
FCPEURO
Post by FCPEURO »
I am thinking they must just bring it right to the edge before the timing needs to be advanced. So getting at least a cat-back is worth it.
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
weired that you all seem to have not so good out comes with cat backs. maybe its because making the exhaust bigger after the cat where the exhaust starts to cool and condense dosent make sense. hense why OBX goes from a 3" downpipe to 2.5. not from 2.25 stock to 2.5. cant make power with the huge factory cat.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
walter leever
Year and Model: 855R,1996
Post by walter leever »
Go for a complete Ferrita system,bit expensive,but is an inox(ss)system,so never have to replace it. :D
Will give about 10 horses(system)and turbo spooling up much easier 8)
walter
9394volvo850s
OBX is stainless steel. and $415 shipped. best bang bor the buck period. just no cat, not a problem in my area.
