2000 S70 GLT SE oil light and stalling and knocking
crisleggett
Year and Model:
Post by crisleggett »
Just today the car started to rattle from the engine almost a grinding. On the way home from school today the rattle worsened and smoke cam from engine compartment. When I pulled in the drive oil light came on checked the levels and they were fine also no indication of overheating from gauge. When I took the extremely hot oil fill cap off smoke came barreling out of the fill hole. I've had a leaky overfill tank for a while now just fill it up bout a pint or so everyday.. Now the car will hardly start idle or move. Please help. is it the oil pump have I damaged the engine. Please advise.
Thank you,
crisleggett
Year and Model:
if it is the oil pump any one have instructions on how to replace I can't afford to down longer than a day. I lve close to the threvolvestore I sure they'll have a pump if thats the problem.
meteg
Year and Model: 2007 V70 2.0T
Post by meteg »
I highly recommend avoiding driving the car.it should sit until you find out whats the problem.. otherwise there might be a serious damage in the engine.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
meteg wrote:I highly recommend avoiding driving the car.it should sit until you find out whats the problem.. otherwise there might be a serious damage in the engine.
+1, I hope the engine is not already past the point of no return. Rattling in an engine and a oil pressure light is a bad sign. Most times, once the oil pressure light comes on, you are already past the point of no return.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Sounds like about how my Saab died...after we got it back from the mechanic, the oil light was on, which he said was 'just a short'. 2 days later, the engine ripped itself apart. I loved that car :(
'98 S70 T5
2016 Chevy Cruze Premier
crisleggett
Year and Model:
I had it towed into the shop just now we'll see... Thanks everyone...
