'97 850 stalling
Hi,my wifes 1997 850 glt wagon stalls right after she starts it.It appears to be running very rich as this happens.The car will start, but when you try to give it any gas it just stalls.I did notice that it has had a very ,veryslight rough idle recently as well.Could it be the oxygen sensor, or the fuel pump relay?.This is our 7th or 8th Volvo,but our first front driver.Thanks for the help.
volvomileage
- Year and Model:
hello
do you have ay codes ?
any work done to the car recently ?
if you feel its the fuel pump/fuel pump relay you could verfiy fuel pressure at end of rail presure should be at over 40 psi and constant...if pressure is below or fluctuates it can be the cause...do you hear a buzz fron the passenger side from the trunk when key at on without starting car ? (fuel pump starting up )
cheers !
cheers !
volvo 850 95 sedan non/turbo 185 k
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
Sounds like your Air Mass Meter sensor is bad. The MAF(AMM) is located on top of the air filter box. If you disconnect it, and the car starts fine, got find yourself a new one. You can get the part here.
Thanks, that would apear to be it.I just removed the air mass sensor and voila! she fired right up!.Will probably order replacement online as locally they want around $250 -325(cdn) plus.Would a used one be wise?Thanks again.
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
Did you try cleaning that one? They rarely fail
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
volvomileage
- Year and Model:
+1 for cleaning maf before changing
you can use maf sensor cleaner or electric contact cleaner (not brake cleaner )
just spray and let air dry never touch the components also clean the connectors contacts...
otherwise if that does not work you can order an used one (order same part number as the one on your maf) or get a new bosch unit either from fcp or an online store..they are much cheaper than the price you were thinking, i would highly recommend bosch (oem)and would not go aftermarket on this part
being in canada make shure that when you order the custom fees are inculded sometimes the price might be cheaper in an othe online store but you might have to pay customs which will increase significatly the price
usually fcp inculdes the customs in their price never had a problem with them
one last thing i would also recommend also that battery terminals be cleaned and well tightened as preventive maintenance....
cheers !
cheers !
- 9 Replies
- 7766 Views
Last post by enriquepr21
- 1623 Views
Last post by jjs70pdx
- 917 Views
Last post by beardface
- 11 Replies
- 1351 Views
Last post by MadeInJapan
- 17 Replies
- 4816 Views
Last post by 850corb
