2002 S60 high fuel pressure
wrgallant
Year and Model: 2002 s60
Been thanked: 2 times
Post by wrgallant »
Another oddity - the return line does not seem to connect to anything. Just dumps over the tank.
Is that where excess pressure is supposed to be returned?
wrgallant
Post by wrgallant »
Another strange thing is that the non-pressure line to the pump doesn't seem to connect to anything.
Just dumps above the tank.
wrgallant
Post by wrgallant »
vtl wrote: 13 May 2022, 09:56 There's a relief valve right inside the pump in your model year, it releases the excess of pressure developed by the pump.
"Car seems to run fine" - but very rich. It will throw a code, if not already.
Any idea why my pump is not releasing excess pressure? I’ve tried 3 different pumps all with the same result.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
wrgallant wrote: 16 May 2022, 19:01 Any idea why my pump is not releasing excess pressure? I’ve tried 3 different pumps all with the same result.
Do you have an OBD-II scan tool? Check the fuel trims, both short term (STFT) and long term (LTFT). Report back. If the ECU thinks its too much fuel, it will move the fuel trims to compensate.
wrgallant
Post by wrgallant »
Short term is 14.1%
Long term is -16.4%
vtl
Post by vtl »
wrgallant wrote: 17 May 2022, 06:52 Short term is 14.1%
Long term is -16.4%
Interesting. LTFT is far on a negative side, this is expected with your fuel pressure. STFT is far on a positive side, this is unexpected. Was it taken on a cold car?
wrgallant
Post by wrgallant »
yes - cold at idle
vtl
Post by vtl »
Ok, can be ignore then. So, yes: either the fuel pressure is really high or the MAF is lying and the ECU has to compensate. Can you read air flow at idle?
wrgallant
Post by wrgallant »
Would that be mass air flow rate?
vtl
Post by vtl »
wrgallant wrote: 17 May 2022, 07:16 Would that be mass air flow rate?
Right. Also what's your idling speed? 800 or 650?
