I replaced the fuel pump on my 2002 volvo s60 2.4m. Car seems to run fine but fuel pressure reading at the fuel rail is 100psi.
No one seems to be sure how fuel pressure is controlled on the module. There is no fuel pressure sensor on the rail. There is no fuel pressure regulator. Is the fuel pressure controlled directly by the ECM? Could the ECM be the issue?
2002 S60 high fuel pressure
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I believe in systems where there is no PEM or FPS present 100% of the demand work is done by the fuel pump alone. I don't believe the ECM would send a pressure setpoint because there is literally no feedback in order to determine where it's at. I think you have a pump issue. Did you use a Bosch branded one? Eager to hear if someone corrects me. My information is based off of research I've done on my own 2004's both of which have no PEM, or FPS.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
There's a relief valve right inside the pump in your model year, it releases the excess of pressure developed by the pump.
"Car seems to run fine" - but very rich. It will throw a code, if not already.
- br0dy519
Is it true though, that models without the PEM/FPS run the fuel pump at 100% duty cycle basically all of the time? I know when I tried to troubleshoot my stumbling issue I was unable to monitor that parameter in VIDA.vtl wrote: 13 May 2022, 09:56 There's a relief valve right inside the pump in your model year, it releases the excess of pressure developed by the pump.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
wrgallant
- Year and Model: 2002 s60
- Been thanked: 2 times
I used a volvo factory fuel pumpbr0dy519 wrote: 13 May 2022, 07:54 I believe in systems where there is no PEM or FPS present 100% of the demand work is done by the fuel pump alone. I don't believe the ECM would send a pressure setpoint because there is literally no feedback in order to determine where it's at. I think you have a pump issue. Did you use a Bosch branded one? Eager to hear if someone corrects me. My information is based off of research I've done on my own 2004's both of which have no PEM, or FPS.
wrgallant
Why is my pressure so high at the fuel rail? I've tried several pumps and they all show the same 100 psi at the rail.vtl wrote: 13 May 2022, 09:56 There's a relief valve right inside the pump in your model year, it releases the excess of pressure developed by the pump.
- 16351 Views
Last post by Richard99
- 688 Views
Last post by v70XCSteve
- 817 Views
Last post by 93Regina
- 669 Views
Last post by oragex
- 34 Replies
- 8725 Views
Last post by vtl
