P80 awd parking brake expander and cables
SwedishMadeFunBrick
Year and Model: Saffron 1998 V70R
Has thanked: 11 times
Been thanked: 4 times
Post by SwedishMadeFunBrick »
10-4 thank you.
Has thanked: 2210 times
Been thanked: 1852 times
Hi Swedish, PM me on MVS and we can set up trying to get that expander to you. Do you have the small dowel pin that holds it onto the end of the cable? Those used to be available. I will see if I have any spares. They are like a little cylinder about the width of the expander and the diameter of the hole in the end of it to attach to the cable.
SwedishMadeFunBrick
On it
And I found one dowel pin, but was going to look for more or make some, shouldn't be too difficult. Might even be able to taper and/stake it to help keep it in place. The one I've found seems very short and is small enough to fall out easily. Even with grease I'd hate to risk it working its way out.
Has thanked: 1611 times
Been thanked: 4075 times
I found a standard pin that worked in my thread
SwedishMadeFunBrick
scot850 wrote: 14 Jan 2023, 14:45 Hi Swedish, PM me on MVS and we can set up trying to get that expander to you. Do you have the small dowel pin that holds it onto the end of the cable? Those used to be available. I will see if I have any spares. They are like a little cylinder about the width of the expander and the diameter of the hole in the end of it to attach to the cable.
Just an fyi, I sent you a PM, or at least I think I did... Only reason I'm skeptical is because it only shows in my outbox and not the sent messages folder. Im assuming that's normal for some reason and it sent but if there is something I'm missing and it isn't as simple as hitting send on a PM, someone feel free to let me know.
Much appreciated!
It stays in the Outbox until the receiver opens it. It helps so you know if it has been received. Hopefully now I have read it it is gone from there.
SwedishMadeFunBrick
Makes sense.
For those that don't know this is the AWD parking brake expander:
AWD P80 parking brake expander
The small dowel pin fits in the hole at the LH end of the expander as per the picture.
The dowel has to be short enough to fit between the sides of the expander as it closes up like a clamshell which then retains the parking brake cable in place:
Pin fitted in expander
The pin is offset just to show it more clearly. When the arm and pin are centered they go between the outer sides to lock the cable in place.
Hope this helps,
