2004 volvo S60 FWD poor acceleration, no power when accelerating
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
nucci480 wrote: 29 May 2022, 12:39 I’m almost wondering if it’s a issue with the traction control system. If pull the battery leads then reconnect them it seems to have the power back. When I test drive it to see if it has torque the wheels will spin a bit. Then it looses all the power on the next launch.
Interesting thought….. What happens when you push the “W” button on and off a couple times.
Do you have the same circumference tires on all four corners?
nucci480
Year and Model: 2004 s60 2.4
Has thanked: 10 times
Been thanked: 2 times
Post by nucci480 »
I will check what happens when I press the W button a few times.
nucci480
Post by nucci480 »
chrism wrote: 29 May 2022, 14:39
I pressed the W button a few times not sure if it is supposed to light up like it’s on. But I did not get any indicator light that it was activated. It did see to have a slower take off though.
All 4 tires were replaced at the same time.
chrism
Post by chrism »
I have a 2003 V70 2.4 NA. Just went out and started it up. The W and an orange light just above the W both illuminate when it’s activated. No indicator on the DIM. I’m not sure about the importance of the lights working or not.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
nucci480 wrote: 29 May 2022, 16:51
thats normal, it starts off in 2nd gear with W selected.
The lock out on the shifter is actuated by the brake pedal so either step on or remove your foot from the pedal in park.
My foot twitches and sets the shifter lockout solenoid off.
nucci480
Post by nucci480 »
When I pull the battery cables off then reattach them it drives fine for a bit. Then It looses power and feels like I’m starting in like 3rd gear.
jonesg
Post by jonesg »
you need vida at this point.
nucci480
Post by nucci480 »
jonesg wrote: 01 Jun 2022, 19:03 you need vida at this point.
I’ve got this Volvo specific scanner. iCarsoft Auto Diagnostic Scanner... https://www.amazon.com/dp/B07F36NJ5K?re ... b_ap_share
nucci480
Post by nucci480 »
I got a used OEM throttle body off eBay to replace the off-brand one I installed. Still did not fix the issue.
