Drive Cycle With Front Wheels Jacked Up
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
abscate wrote: 16 Jun 2022, 04:41
MrAl wrote: 16 Jun 2022, 02:48
erikv11 wrote: 15 Jun 2022, 13:43 Are you sure you even need the monitors ready?
I thought most (all?) states gave exemptions for monitors on a 98 Volvo. I know CA does and they seem the most restrictive.
Hi,
How did you find that out?
I read on the New Jersey site that cars 1998 are allowed 2 monitors not ready but that coul dbe for other cars.
How would i find out otherwise?
The policy is set by the states , following EPA guidance at their discretion. The NJ DOT website would be definitive here
A simple weak battery orbadatteryvcable(s) causing voltage to drop on cranking, would reset the monitors on restarts
Hi,
Yeah i checked a little and found that it seems true that California allows the 1998 to be exempt completely but New Jersey is a stickler for stuff like this so they wont let it go that far. It's funny too cause CA is very smog aware.
MrAl
Post by MrAl »
kallekula wrote: 16 Jun 2022, 07:00 I used to have a real nice smog guy checking my car. Sometimes if the monitors weren’t complete he would take care of it running the car on the rollers in the floor. He obviously knew the drive pattern for a Volvo, maybe they are about the same for other cars as well?
EDIT: I take that back. My BMW goes through all checks really quick compared to a Volvo.
EDIT2: Engine must be cold when starting to drive. Think I missed that a couple of times and had to redo it all over again.
Hi,
Oh so he ran it on the 'rollers', i am wondering if they require some toque to turn i bet they do, or may be controllable to some degree as to the amount of torque they require to turn. If they dont require any torque than jacking should work too i guess.
Do you have same year car (1998 v70) ?
Thanks.
MrAl
Post by MrAl »
ZionXIX wrote: 16 Jun 2022, 07:43
MrAl wrote: 16 Jun 2022, 02:51
Oh that's a strange one. I wonder why that happens.
The problem with this car is it takes several startup and shutdown cycles to get the monitors to flip to ready. Usually i just drive around in my usual routine of going to the store and a few other places and the go ready. That takes about a month or two i think. This time i am a little pressed for time because inspection is due end of month.
My monitors will fully set on a 20 min drive to work everyday. No paying attention to any of the drive cycles.
Hi,
Do you remember how many times you had to go back and forth to get them to go ready?
Also, do you have the same year and model car 1998 v70?
Thanks.
Has thanked: 1611 times
Been thanked: 4075 times
Clarification, they don’t reset every time you drive the car. They go ready and then monitor the emission systems every time you drive the car. You need them in the ready condition to pass emission inspection so that the inspector knows they are working, have scanned the systems , and found no faults.
Ny follows the EPA guidelines, I have passed some of my 99s with Evap not ready. Not all states follow the EPA guidelines.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
MrAl wrote: 17 Jun 2022, 04:29
Hi,
Thanks.
I have the 2000 S70 with Denso electrical system.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Just try. Put the car on blocks and run the drive cycle. If it works it works.
BMW 540i 2002
S70 Base 2000
MrAl
Post by MrAl »
kallekula wrote: 17 Jun 2022, 08:06 Just try. Put the car on blocks and run the drive cycle. If it works it works.
Hi,
I guess i was wondering if someone already knew because i guess i would have to buy jack stands to try it.
Also i'd have to find out how to use jack stands on this car not sure because this car is weird even for jacking up.
kallekula
Post by kallekula »
Drive the cycle then, it works. The hardest part is finding a stretch of road to be on. Oh, and to remember to start with a cold engine.
BMW 540i 2002
S70 Base 2000
MrAl
Post by MrAl »
kallekula wrote: 18 Jun 2022, 04:57 Drive the cycle then, it works. The hardest part is finding a stretch of road to be on. Oh, and to remember to start with a cold engine.
Hello again,
Well you ready for this...
My neighbor took the car out to get gas, and the damn gas cap was missing !!!
The guy who repaired the car for $2800 didnt have the gas cap on when he was driving it.
We went to Auto Zone to get a new cap (it's close by).
The new cap has a stretchy thing connected to it you screw to the gas door. That keeps it with the car even when the cap is off.
I cant believe what a jerk.
Well, that might solve the Evap monitor problem….😀
