Alternator arrived -- I have a tensioner that has what looks like a 14MM bolt on the pulley. I can't see the torx fitting - maybe I have a different type? I saw a vid where the guy used a socket on the pulley bolt to release tension, but is this OK, and how would I get the belt back on? Maybe there is a T45... I can't find a picture of the type tensioner I have.
Meanwhile, the Amazon delivery guy ran the truck off my driveway, and is stuck, so I can't go anywhere until he gets towed out..
failing alternator or belt?
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Thanks - Where is the t45 hole on the casting? I can't see it.. I'll use the 14 to loosen the tension but I'm concerned with loosening the bolt when I have to pull the tension back to replace the belt
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
azureblue wrote: 15 Dec 2022, 09:38 Thanks - Where is the t45 hole on the casting? I can't see it.. I'll use the 14 to loosen the tension but I'm concerned with loosening the bolt when I have to pull the tension back to replace the belt
You actually release the tension by turning the bolt CW, so it is tightening the bolt, not loosening.
azureblue
Thanks but the picture is not what I have. Mine has a 14MM bolt through the middle of the pulley, and this kind of looks like a T60
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 20 Replies
- 7405 Views
Last post by tonie
- 1049 Views
Last post by vtl
- 13 Replies
- 2868 Views
Last post by obayha
- 3891 Views
Last post by precopster
- 1523 Views
Last post by frknvgn
