Hi all:
My dash guages, displays, and lights are intermittently failing. Sometimes all the lights and displays go dark, tach, speedo, fuel and temp gauges drop to zero or will be stuck at a reading, all display icons may be lit at times, when I shut the car off dash lights may stay on. While driving everything may work normally, then problems occur again. I am thinking a short/loose connection in the wiring. Just wonder if anyone knows the best connection(s) to start looking at before I have to tear off the dash and start checking everything.
Thanks.
2002 V70XC Dash failing
- Been thanked: 4064 times
First thing to check is ignition switch. Try wiggling the key when the lights go to see if you can get them back
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If the DIM its failing, repair service is $150 on Ebay. But check the other things first, ignition key, alternator, CEM
EChem
- Year and Model: 2002 S80 T6 Anniv Ed
- Has thanked: 1 time
Thanks for the replies. I have wiggled the ignition and it never caused the gauges to come on. Would a problem with the DIM cause all 0f these gauge problems more so that a wiring short or harness connection problem?
- 11 Replies
- 1686 Views
- 13 Replies
- 2862 Views
Last post by obayha
- 3879 Views
Last post by precopster
- 1517 Views
Last post by frknvgn
- 13 Replies
- 3282 Views
