That is a serious o-ring and a clever fix.
Question - Is wiggling the subframe around changing the alignment? Or when you do them one at a time it doesn’t move?
Basic testing of sub-frame bushings? ('04 XC70)
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
With only one rear bolt loose, the subframe shouldn't move much.BlackBart wrote: 08 May 2023, 08:42 Question - Is wiggling the subframe around changing the alignment? Or when you do them one at a time it doesn’t move?
Because of the alignment pin on the driver side (can see it in picture above), the subframe needs to lower quite a bit in that corner. You may need to disconnect the upper engine mount and unlock the steering shaft, so it could follow the steering rack.
