What could this noise be?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Vacuum leaks affect LTFT (and STFT when they are huge). Easy to check with any OBD reader.
Has thanked: 2202 times
Been thanked: 1852 times
These engines on the P2 can get loose exhaust manifold bolts/nuts which then causes a blow.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
So, I got the spare brand new pump + gasket I had lying around but completely forgot the stethoscope.
Is there anything that could go bad if I run the car without the serpentine belt which will not spin the alternator.
vtl
Post by vtl »
No.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
dikidera wrote: 22 Nov 2023, 08:44 So, I got the spare brand new pump + gasket I had lying around but completely forgot the stethoscope.
i drove mine home 40 miles when the acc belt broke,
i made it and the car still had enough power to crank again when i got home.
jonesg
Post by jonesg »
when it starts whistling loosen the oil dipstick and see if the noise goes away.
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Been thanked: 6 times
Post by famfeld »
Disconnect serpentine belt and run to see if it goes away
dikidera
Post by dikidera »
Late to the party but I just got back. I removed the serpentine belt, started the car and the noise was gone. I noticed the serpentine belt tensioner's pulley was first hard to turn and had no inertia to it at all, secondly it had some radial play. I am guessing it has gone bad. The alternator pulley was normal and I couldn't tell anything about the AC compressor. The PS pump had some slight axial play.
I reinstalled the belt, started the car and sure enough the noise was back. So while I can't say it's from the tensioner for sure, it is coming I believe from a belt accessory.
vtl
Post by vtl »
Don't run it like that, it may cost you an engine.
dikidera
Post by dikidera »
I don't really have a choice until I get a replacement part Monday or at best Tuesday.
