I'm affraid that something could go wrong with TCM when you install an ECU from a manual donor car into a car with auto transmission.P80joan wrote: ↑09 Jan 2024, 10:49
One important question before I do this:
Is there any risk of electrical/software issues when swapping around ECUs and immos?
Is it safe to start the engine with a possibly not compatible tune? (mine is still an automatic, donor ECU for manual; also different ECU numbers)
Codes stored in TCM will NOT reset untill read & clear with proper scan tool(Vol-FCR,dealership).
Disconnecting battery cables doesn't do the trick on TCM like on ECU.
