Where is this cracked elbow located? Totally new to Volvo and am not yet familiar with the terms.akitawagon wrote:I'm not sure if my issue is the same as yours, but I had a fairly loud tapping/fluttering/ratcheting noise (almost sounded like a mechanical problem) that occurred when giving gas for accelerating or climbing hills.
I thought it might have been an exhaust leak, but turned out to be that one of the elbows attached to the vacuum tree by the IAC valve had cracked at a bend that wasn't visible until I removed the vacuum tree for cleaning out the throttle. Fixing the bad elbow seems to have eliminated the tapping/fluttering noise and my car feels like it's gained some of its low end torque back.
Tapping noise during acceleration on 1998 Volvo S70 GLT
1997 850 T5 DD in NoVA 77,500 miles
mods: Twin Britax Marathons
- akitawagon
- Year and Model: 1997 855R
Hi jeovaz,
If you you remove the black plastic cover over the throttle that is held down by one torx 25 or 30 screw, you will see the Idle Air Control Valve (IAC) and behind it is a vacuum tree with multiple ports. One of the hard vacuum lines with the rubber elbow had a big crack in the inside bend of the elbow.
I'll try to take some pictures tonight if I can. My reason for the "single Britax modification" may keep me busy for a while...
BTW, I've been able to drive and push the car a bit harder over the past couple of days, and while the noise is still kind of there, it is not as loud as before. So... I'll be eventually replacing all my vacuum lines with silicon lines.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
MadeInAmerica
- Year and Model:
Vacuum tree pic '94 850 Turbo
'94 850 Turbo 160K Automatic
[Autometer Sport/Comp Boost Gauge][Silicone Vacuum Hoses][Walbro Fuel Pump][New OEM Torque Mount][Yokohama YK520][New PCV system+Air Intake Hose][Magnaflow Cat at 160K][Borla Pro XS Muffler 162K]
Thanks for the picture and help akita. I checked mine and my connectors are are all intact as well as the tubing. I'm still hearing the noise.
It may not be a lifter noise... I kinda notice that the noise is kicks in with the turbo, which could be exhaust related.
BTW, the picture you posted confirmed that I am missing an air intake tube from the top of the radiator to the bottom of the fileter box. the former owner probably missed to put it back. Right now I palced an Al duct to get some colder air into the intake.
Thanks again for the help.
- 1066 Views
Last post by Clockboy
- 1649 Views
- 997 Views
Last post by mdelaine
- 15 Replies
- 7214 Views
Last post by WarbirdPilot91
- 1370 Views
Last post by sbattaglia
