Flare nut size for brake lines
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
vtl wrote: 24 Mar 2024, 07:41
That's brake hoses =) Lines are made of stainless steel if I'm not mistaken.
or nickle copper ni/cop.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
On the front and rear, the correct flare nut size was 13mm for the inner soft flare nut. The brake hose was 14mm which you don't really need a flare wrench for. I'm not sure how widespread this manufacturing defect is, but the flare nut wrenches from harbor freight has a 14mm size on both ends even where it is labeled as 13mm.
2002 v70 X/C 288k miles
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
That's aggravating, isn't it?
Has thanked: 1609 times
Been thanked: 4065 times
That’s really , really annoying. Flare wrenches are one of those tools you need infrequently, but when you do, you want quality. sK, Snap on, Tekton brand is probably worth it. You don’t need to buy the whole set
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
Project Farm recently did a test on Flare Nut Wrenches:
He always does no-BS tests of the tools and is not sponsored by the manufacutrers.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
abscate wrote: 09 Apr 2024, 02:00
You don’t need to buy the whole set, BUT if you do much wrenching and you may have corrosion and previously damaged bolt heads, a set of flare wrenches can save frustration. A flare wrench does not grip as well as a 6 point socket, but better than a plain wrench or 12 point socket. Sometimes there is no room for a socket wrench.
