I know. I will try to put another radio in when I have time and I will check. I don't know what else to do right nowmisha wrote: 28 Jul 2024, 11:19 Aftermarket radio should have euro connectors...so you couldn't fry it.
Even if it doesn't have them...it have a fuse which would blow on short.
Problem after dashboard replacement
perhss70
- Year and Model: s70 1997
- Has thanked: 6 times
- Been thanked: 3 times
'97 S70 2.0T5
- Has thanked: 1614 times
- Been thanked: 4078 times
An aftermarket install can be wired in just about 1000 ways. Tough to web-assist.
perhss70
Yeah I know. I was just wondering if it is a common problem for some wiring to go bad or whatever info I can get that will help me with troubleshooting the problem myselfabscate wrote: 29 Jul 2024, 03:15 An aftermarket install can be wired in just about 1000 ways. Tough to web-assist.
'97 S70 2.0T5
perhss70
It seems like I'm missing the second plug that goes to the stock radio (the smaller one). Is this a part of the dashboard wiring or the wiring that sits on the car when you remove the dashboard?
'97 S70 2.0T5
- Has thanked: 2215 times
- Been thanked: 1853 times
Do you have the amplifier option on your car? Either way it should still be there if you are using the standard wiring loom for the speakers. I don't believe it can be removed separately from the loom. It must be stuck or hidden somewhere as you would need it for even the aftermarket radio. The amplifier version just uses one of the wires (a yellow) one, the regular no amplifier version uses all the wires for speakers.
- 827 Views
Last post by Fiodor
- 1406 Views
Last post by laurentius
- 13 Replies
- 3069 Views
- 137 Views
Last post by jreed
- 675 Views
Last post by Jonesroad
