Vibration under seat at most speed
arrrxivvv
Year and Model: 2004 XC70
Has thanked: 16 times
Been thanked: 10 times
Post by arrrxivvv »
Thanks, perhaps I'll wait a while since the vibration is not yet too bad.
jonesg wrote: 09 Sep 2024, 02:50 wheel bearings drone or hum.
friction noise, more likely to be the dust shield or brake shoe/pad clearance but you wouldn't feel it in the driver seat.
pain in the neck but you could reinstall the prop shaft to eliminate. or disconnect it to eliminate anything in the rear end.
or turn the radio up and wait til it becomes more obvious.
04 XC70 206k
arrrxivvv
Post by arrrxivvv »
Thanks for the suggestions. Parking brakes have been replaced last year. The tire shop rotated the tire too.
scot850 wrote: 09 Sep 2024, 05:54 Check your parking brake shoes have not delaminated and come loose. They will cause a vibration and dragging.
Have you tried a tire rotation to eliminate a bad tire or bent rim?
04 XC70 206k
Has thanked: 2196 times
Been thanked: 1850 times
If they rotated the tires and the shake is still through the seat, it is not the wheels or tires if you are not feeling it through the steering wheel too.
The parking brakes could still be the issue. A stuck parking brake cable, or a sticking rear caliper will also cause these issues. After you have driven the car, CAREFULLY!! touch the rear wheels near the center and feel if either hub is hot. Careful it can get really hot!!
arrrxivvv
Post by arrrxivvv »
It's interesting to know about potential parking brakes issue. Just finished a drive, the rotors were warm but I was able to briefly touch them without burning myself.
scot850 wrote: 09 Sep 2024, 18:40 If they rotated the tires and the shake is still through the seat, it is not the wheels or tires if you are not feeling it through the steering wheel too.
04 XC70 206k
