FLAPS is a pretty risky source for a fuel pump. Last time I went that route the pump lasted 6,500 miles!
The Bosch pump is like $150 from FCP. $240 all in with the special tool (worth it) and the o-ring.
Can't find fuel filter '05 V70 N/A
- Has thanked: 312 times
- Been thanked: 818 times
For your 2004 Volvo V70, the fuel filter is typically located on the right side of the vehicle, just ahead of the rear wheel, mounted along the frame rail. However, it's possible that your model may not have an external fuel filter; some 2004 V70s have the fuel filter integrated into the fuel pump assembly inside the fuel tank, which doesn't require regular service.
Double-check the area on both sides of the vehicle near the rear wheels. If you still can't find it, consult your owner's manual or a service manual specific to your V70 model year to confirm if your car has an external fuel filter or if it's integrated into the fuel pump.
just in case anyone is curious i own an auto repair shop in manchester nh
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
I have begun removing the fuel pump from one of my parts cars, an '04 V70, also a B64. Nothing about the pump looks similar to a pump R&R I have found on the net. It is held in by a metal ring, as opposed to a composite. In trying to remove it, I think that I find it is bolted to the tank (there is still some gas in the tank)erikv11 wrote: 12 Sep 2024, 21:27 FLAPS is a pretty risky source for a fuel pump. Last time I went that route the pump lasted 6,500 miles!
If anyone can point me to a video of this model, I would appreciate it.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Try this video, Peppermint is pretty good:
Or this?
Faust
Thanks, those look much more like the pump I have (steel tank). A good deal more complicated too.
2004 V70
- 2133 Views
Last post by peripatetic
- 1006 Views
Last post by mrmail
- 1456 Views
Last post by jonesg
- 1282 Views
Last post by configsys
- 154 Views
