How to install harmonic balancer/crank pulley?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
leapdragon wrote: 25 Apr 2026, 00:01 Okay, have ordered the 1/2 700 ft lbs guy.
Still same concern... If I use the ugga dugga tool to get it off...and then back on... Will I kill the timing belt? Do you usually replace that as a matter of course when replacing the crank pulley for that reason?
Crankshaft will not move even without timing belt: compression prevents that.
Look at your pulley: if you see rubber cracked it's better to replace it. It may cause excessive vibration and more stress put on the main bearings.
