Oil Leak - Rear cam seal Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
Alas and thanks for keeping the economy going, but a least you'll know it is clean going forward. I'd be sure to replace that banjo bolt, whether the old one looks good or not.
ok, lets go ahead with the dumb question. so what I was concerned about was the really small lip at the red arrow being folded in at a few spots. Which I could barely see but I got ocd in my inspection and noticed it. after i pulled the seal thinking that was a failed install it seems maybe this part of the seal isn't of much significance. the inner seal yellow arrow I guess is what is of importance? because that small outer seal is so insubstantial in its thickness that I see no way of keeping it from folding in some using the install tool. any thoughts?
- Been thanked: 504 times
Do a Google image search using key words "seal garter spring", which sits under the YELLOW arrow.
The RED arrow is simply a "dust sealing lip", just to keep debris from getting to the main seal
Thanks. You’ve helped me more than anyone else in my life today, but the day isn’t over yet lolcn90 wrote: 09 Dec 2024, 15:32 Do a Google image search using key words "seal garter spring", which sits under the YELLOW arrow.
- 807 Views
Last post by kahl
- 9738 Views
Last post by tyguyc
- 1499 Views
Last post by iRenaissanceMan
- 1360 Views
Last post by RickHaleParker
- 1156 Views
Last post by warcoy99
