At $100, that's a steal. Very pretty wagon. Some stuff you need:
New head gasket
New head bolts - they are one time use
Anaerobic sealand to seal up clamshell cover
Special tool kit used to align cams and wind down clamshell. (eBay)
Water pump
Timing belt
Timing belt tensioner
You may be able to just use that head as is, but check it with a metal straight edge, width, length and diagonal, you shouldn't be able to get a 0.006 inch feeler gauge under the straight edge. If you can, the head needs decked at the machine shop.
Also get a cup of water and fill up the combustion chambers. Does it just run all out on the table? If so it's machine shop time to do a valve grind.
A $100 '99 V70 GLT Topic is solved
- Oly850
- Year and Model: In acquisition mode.
- Has thanked: 53 times
- Been thanked: 22 times
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell.
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Yeah it is a nice color. It should polish up ok in most places.454cid wrote: 01 Feb 2025, 09:23 Very nice. I do like the color. It's similar (the same maybe) as my 850. I'm a little surprised you didn't look for a whole engine to swap in.
I can't imagine how a guy would lose a head, but some people are "amazing".
I figured replacing just the head was more straight forward. But we will see. If the $100 head I bought also turns out bad, then who knows. I'm trying to find a shop to check it.
I think the previous owner removed the head, dropped it off at a shop to be checked/milled, and was told that it was to badly warped to be used. Guessing he just left it at the shop at that point. That was 3 years ago
1999 V70 GLT
1999 V70 GLT
- Sveedy
Oly850 wrote: 01 Feb 2025, 16:04 At $100, that's a steal. Very pretty wagon. Some stuff you need:
New head gasket
Water pump
Timing belt
You've barely touched my list
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1611 times
- Been thanked: 4075 times
In this case the head job is already half done, and the PO has done the nasty part!
You can use Permatex for the cam cover at 1/5 the price of the Volvo brand.
Pm me if you need any of the specialty tools for this job.
- Sveedy
Well I got it up on the wheel cribs in preparation for the oil pan removal.
The wheel was actually rusted on ( no small feat here in AZ ) and I had to use a crow bar to pry it off.
Engine compartment is cleaning up nicely. Need lots of wire loom....
1999 V70 GLT
1999 V70 GLT
- Has thanked: 987 times
- Been thanked: 1078 times
Be sure to find High Temp wire loom, so it will last longer.
- Has thanked: 2210 times
That loom covering is a standard fair I have found. I have spent many hours recovering the looms on old Volvos with crusty wiring covers.
I am amazed at the engine bay pictures. Have you done a lot of cleaning there before the photo? It looks cleaner than any engine bay and front of the engine I have seen. Project is moving along great it looks like!
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Love that billet plywood head.
Note: on the wiring loom. Mine is in decent shape, but every time I look at a P2 at the auction it's barely there.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Sveedy
Yeah I wanted to make sure no critters made a nest in one of the cylinders while I had it outside.
The engine looked like it had never been cleaned, so I hit it with repeated sprays of hot water w/ dish detergent and let that soak. Putty knife and wire brush. Then followed that up with some throttle body cleaner.
I have found high temp wire loom online, but in 100ft lengths. Since I want 3 different sizes of loom, I'd end up with 300ft of the stuff ! Just a little bit more than I think I need.
1999 V70 GLT
1999 V70 GLT
I got some off Amazon in shorter lengths. Not as good value as the longer lengths but like you, I did not want a bunch left over.
I don't know if this is available on Amazon in the US, and if the link will work when posted.
https://www.amazon.ca/dp/B092ZB365R?ref ... title&th=1
I found it on Amazon.com:
https://www.amazon.com/ZhiYo-13ft-1-13f ... F0aWM&th=1
