Stripped AC drier threads taking hose 9171319 off
Nice ! I’ll try that next time. Looks a lot easier for torque than by Uber long extension
- rudsaki
- Year and Model: 1998 S70 T5
- Has thanked: 29 times
- Been thanked: 16 times
My goal here was new orifice tube and drier with clean refill. Tube not the worst, but dirty. Drier very heavy with metal clanking when shaking it.
Put in two full 12oz cans, so I still owe it 2.6.
35 degrees out the vent at idle. Pipes got frosty. Only 80 deg 30% humidity test drive went well sticking around 35 vent temp at max cool and 40 when auto temp set at 72.
Need 100 degree day for final temp test.
Thanks to all for the advice
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
Don’t add anymore refrigerant of you are getting 45 F delta! That’s awesome and you ll likely overcharge .
Two cans 680 grams is about 90% of full charge “ spec “ of 750g , many systems will cool better a bit lower than “ spec”
Last note. Usually Volvo is good for designing softer metal on consumable parts and harder metal on long lived parts. Have you tried digging out the thread metal with a pick on the hose, to see if it can be saved?
- 760 Views
- 962 Views
Last post by fixer333
- 3153 Views
Last post by pmondrian
- 1024 Views
Last post by subzerocarfanatic
- 624 Views
Last post by HerrGruyere
