V70 P2 PCV breather hose replacement on a non-turbo engine
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Is that an LPG vehicle?
04s60 2.4
04xc70 2.5t
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Would removing the upper radiator hose allow you enough room to reach the hose?
BTW that’s an interesting injector setup. I’ve never seen one like that.
Lordflash
Year and Model: 2006 V70 P2
Post by Lordflash »
It’s an BRC LPG system yes, works flawlessly.
Radiator hose alone is not enough, possibly steering pump and alternator, but I guess it than is better to just remove the intake manifold.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 67 times
Been thanked: 94 times
Post by DavidE7 »
Remove the fat rubber hose between the air filter housing/mass airflow sensor and the electronic throttle. There will be very limited visibility but enough space to feel what you are doing. Your visibility is extra limited by the LPG components blocking the small view spaces between the 5 intake pipes of the manifold. As explained in a prior post, removing the throttle body also helps increase clearance and allows you an opportunity to clean the buildup of oil and carbon which usually improves idle smoothness.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
Lordflash
Post by Lordflash »
So replaced the hose today, did have to remove the inlet manifold as there was no way that you could remove the clamp on top of the oil trap. After replacement did the glove test and there is a slight vacuüm so thats good. I do have a slight whining noise now which stops when removing the dipstick or oil cap. Do I have to dig in again and replace the oil trap due to a possible stuck membrame?
chrism
Post by chrism »
Lordflash wrote: 12 Apr 2026, 14:23 Do I have to dig in again and replace the oil trap due to a possible stuck membrame?
Yep, most likely. The diaphragm gets all coked up and ruptured and won’t function as intended. That subjects the crankcase to more vacuum than normal, hence the whistling noise.
Years ago I cut one open and posted a photo of the inside - hit the link below.
download/file.php?id=69659
Lordflash
Post by Lordflash »
Ok thanks. So and it is possible to have a broken diaphragm and still have good vacuüm? Theres defenitely not too much vacuum.
br0dy519
Post by br0dy519 »
Please replace the banjo bolt while you're in there!! Many threads on this issue describing catastrophic damage with a poor obsolete design in early years.
04s60 2.4
04xc70 2.5t
Lordflash
Post by Lordflash »
I did not encounter a banjo, think that is only aplicable to turbo cars?
br0dy519
Post by br0dy519 »
My bad.. yes it appears yours doesn't have it nor a coolant line from the thermostat. I swear I did the replacement on my 2.4 ...
04s60 2.4
04xc70 2.5t
