deferred maintainance is all that is.
If the belt is oiled it should be changed, any seal can be done at that time.
Loosen the oil dipstick to relieve crankcase pressure for now.
Sometimes the seal can be pushed back in place but the pcv has to be fixed as vacuum is what keeps the seals in place.
I don't think things are so bad at all, if the rear main seal had blown out youd have to pull the trans to fix that.
Its not like you crashed the valves and need to replace the head for $900 just in parts.
You can do this, its not major engine work.
Persistent Check Engine light, but no codes thrown - 2001 S60
- paul1149
- Year and Model: 2001 s60
- Has thanked: 12 times
- Been thanked: 5 times
Thanks, that's a great idea about the dipstick. This is on the outside edge of my experience, and I'd be working outside on the driveway. And I'm starting a new job this week and need reliable transportation fast. So it comes at a really bad time and I think I'm forced to move on.
- Has thanked: 1613 times
- Been thanked: 4075 times
I’ve got a student loaner car in CT I need to move out asap, could that work as a bridge until you get the s60 dealt with?
How long is your daily commute!
I’m overseas at moment, back this week.
With oil leaks you have to get the oil cleaned off, and then go looking hard to find it.
95% of the time its a cam seal and those are cheap to do.
Front crank seal is very rare failure.
- 1350 Views
Last post by FLXC90
- 6594 Views
- 383 Views
Last post by jonesg
- 1054 Views
Last post by Klausc
- 3700 Views
Last post by SuperHerman
