2007 XC70 Air Bag Removal Torx Bolts not a screw driver release! Topic is solved
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Sorry, I didn't realize they were different.
2003 XC 70 (sold)
- Blacklab467
Here is the page from VIDA on the 2007 airbag removal, I really don't think anything has changed in the design, can you post a picture of your wheel, front and back?
2003 XC 70 (sold)
8pack
- Year and Model: 2007 XC70
- Has thanked: 3 times
- Been thanked: 2 times
Been in here another hour and 1/2 trying both sides. Have the camera in there. I just can't see how the tab moves to release it. I can't see that little lever that is shown in the pictures with the camera, nothing. I am prying up as hard as I can with the blade above the tab and below the tab. Nothing.
I don't know what else to do unless someone else here with an '07 XC70 can please, please chime in. It is clearly different than what others have posted so far.
8pack
Here is an eBay Ad for an airbag that looks like mine. It does not have the post like the others. In the second to last picture look at the tabs. Those are the tabs I have sticking through the hole.Blacklab467 wrote: 21 Dec 2025, 10:01 Here is the page from VIDA on the 2007 airbag removal, I really don't think anything has changed in the design, can you post a picture of your wheel, front and back?
There is no little lever I can see looking in the hole. I will take some more pics with the camera to see if you can see it better. Here is my steering wheel front and back.
EBAY AD
https://ebay.us/m/mSb5ED
- Blacklab467
did you remove the two torx screws?
2003 XC 70 (sold)
- Blacklab467
Ahh I see what you mean, it is different! I would try prying that tab to the outside and see if it releases, one side at a time while pulling on the airbag. If that doesn't work, try prying it to the inside.
2003 XC 70 (sold)
8pack
Hmmmmm. No. That was not in any of the instructions anywhere including the VIDA.
I will try that now but they will have to be really long to reach the airbag.
Stand by
Stand by
8pack
You mean pry side to side instead of up and down?Blacklab467 wrote: 21 Dec 2025, 11:39 Ahh I see what you mean, it is different! I would try prying that tab to the outside and see if it releases, one side at a time while pulling on the airbag. If that doesn't work, try prying it to the inside.
Here are pics from inside the hole.
Pic 2 is with the tab bent up so you can see what is underneath it. No lever. Just the backing plate for the airbag.
Pic 1 is with the tab bent down and you can see a solid piece of metal there where my screwdriver has been banging into it and scraping it up. No lever.
A couple of other pics for perspective.
8pack
Here's what I just found on Volvo forums. I have been searching for days. When I added the word "Vida" to the search this thread came up. Exact same issue I am having.!! I can't get the torx screws to move is my problem now. I can't tell if they are T25 or 30.....
https://volvoforums.com/forum/2001-2013 ... e_vignette
- 1121 Views
- 976 Views
Last post by fixer333
- 2448 Views
Last post by Ozark Lee
- 3249 Views
Last post by SuperHerman
- 18 Replies
- 3790 Views
Last post by Grantkat
