No heat in Vermont from 2003 xc70
SailorSteve22
Year and Model: 2003 Volvo xc70
Been thanked: 2 times
Post by SailorSteve22 »
Fyi. After messing with the settings to get the door in the right place I then disconnected all the actuator doors only passenger side.easy enough. Now have cabin heating . I'll leave it like this til spring/ summer
SailorSteve22
Hello everybody. I thought I'd fixed the heate issue but I have not. I tried swapping out the CCM. That didn't work either. When I bought this car it had a faulty instrument cluster that would go on and off so I swapped it with my V70. I think this could be the reason for my lack of a heater. With the blower off I can feel hot air coming through the vent. When I turn it up to one it's ok but as soon as I turn it up to two and beyond the air turns cold or warm at best. Can anyone give me any insight on what I should do?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I'd check and replace:
- Thermostat Wahler is OEM, but I have used Facet brand (,made in Italy) w/o any issues. Facet is much cheaper.
- Heater core may be blocked.
I posted the experience of my 2005 XC90 2.5T in XC90 forum...
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
cn90 wrote: 20 Jan 2026, 21:02 I posted the experience of my 2005 XC90 2.5T in XC90 forum...
Here it is:
DIY: 2005 XC90 Heater Core Replacement
Also -> Amazon link
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
So the more air you blow across the core, the colder it is. I think CN90 may be on to something with the idea of a partially plugged-up core. At this point I think I would disconnect the heater hoses at the front side of the firewall (twist disconnect) and shoot water through the core with a garden hose. Run the water through in both directions, alternating several times, and see what comes out.
Don’t hold the garden hose TOO tightly against the firewall connectors as your houses water pressure may exceed what the heater core can handle.
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
grab or shoot the hoses with a temp gun, they should both be hot, one hotter than the other if theres flow.
