V70 2002 - power steering fluid filter?
MotorTheresa
Year and Model: V70 1998 B5252F/S MT
Has thanked: 33 times
Been thanked: 15 times
Post by MotorTheresa »
Thank you all for the feedback you've provided. The correct spec fluid is already ordered and we're right now waging reservoir cleaning vs. buying the 2005 to retrofit.
Will keep you updated!
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Its only a matter of time. The pre 2005 failure is the snorkel inside of the reservoir which rots away over time and either causes a catastrophic leak or an obstruction in flow. Both are bad for the rack which you dont want to replace. Like ever.
04s60 2.4
04xc70 2.5t
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
vtl wrote: 19 Mar 2026, 09:42 I cut a rubber portion of the return line and added a 3/8" (10 mm) Magnefine filter in there.
It also helps installing a heat shield over steering rack to protect it from the exhaust heat. Volvo had it for earlier model years. I bought one for my 2005, but it does not fit.
I just ordered 2 Magnefine 3/8" filters. Both the ATF and PS fluid are due for a change so I'll add on these filters. I already have one on the ATF return line but will be the first time PS fluid hose is getting one. For fluids I use Pentosin CHF 202 PS fluid and Volvo ATF. I change the ATF quite often so I'll just use the drain bolt. For the PS fluid after disconnecting the hoses I'll use the long tubes on the fluid extractor to remove most of the PS fluid.
Has thanked: 1611 times
Been thanked: 4075 times
I did not know turning the wheel will pump oil out, having done the frantic “ power flush” a few times , that’s good to know.
Fora> shared knowledge > power > world domination> sitting on sofa with dog and partner eating pizza
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Yeah,
Been there done that with engine running lol. I stop doing that, it is too dangerous.
I then turn SW with wheels on the ground, then discover that with a floor jack lifting front subframe, tires don't have to leave the ground, as long as some weight off the ground then it is easy to turn SW.
With everything so expensive now, and dealer charging $180-$200/h, idk how ppl can afford to pay for car repairs.
That’s also brilliant and much safer getting in and out.
A jacked up car with two front wheel contact points isn’t going anywhere
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 21 Mar 2026, 13:17
Fluid extractor makes it a breeze. And they are real cheap now. And you need one for unmodified bevel gear and rear differential, which have no drain holes.
XC70Rider
Post by XC70Rider »
Finally got around to adding the Magnefine filter onto the PS return hose after siphoning out most of the PS fluid. After taking this picture I wrapped the filter with heavy duty aluminum foil.
I also replaced the Magnefine filter on the ATF return hose.
Next drive I'll see if the high pitched squealing goes away while taking those slow sharp turns. First time I changed the PS fluid in 48k miles. :x
UPDATE: No squealing during the drive today. There was no air in the system. The fluid was just past it's changing date. I got it marked to change it next at 30k miles.
magefine filter.jpg (8.25 KiB) Viewed 1074 times
MotorTheresa
Hi y'all, so the flush went really good and the all over steering effort reduced to a reasonable amount now.
The fluid was worse than anything I saw so far.
Anyhow it is uneven with some occasional increases of steering force. Spikes.
Needless to say this is NOK to drive as a family car.
We have a spare P/S pump which we try to see if that's is the culprit. Worst case is that the steering gear has taken damage over the years of neglectance. Bummer
vtl
Post by vtl »
MotorTheresa wrote: 06 May 2026, 21:53 Hi y'all, so the flush went really good and the all over steering effort reduced to a reasonable amount now.
Have you replaced intermediate steering shaft? A small shaft with U-joint between steering rack and steering column.
