Passenger Axle & Strut Replacement ('04 V70)
BobbyC777
Year and Model: V70 2.5T, 2004
Has thanked: 27 times
Been thanked: 7 times
Post by BobbyC777 »
Thanks, @cn90. I will check out that previous thread of yours. (I looked before posting but too many hits to track them all down.)
Here is the link to cn90's DIY article on alxle and seal replacement:
https://www.matthewsvolvosite.com/2004- ... s-diy-fix/
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Everything is in this thread below...from tricks to seals to how to install the seals and the red grease tip and how to make seal tool using wood (and mistakes learned)...
2004 V70 Axle Boot DIY
viewtopic.php?t=91594&start=30
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I wouldn't mess with the axle seals on a P2 car if they are not leaking. The P2 axle seals don't actually contact the axle shaft, they seal a cup that surrounds it. So far, I've not had a P2 axle seal leak in my three high mileage cars.
P80 car yes, P2 car no, that's my routine on axle seals when the CV axle is out.
Has thanked: 2207 times
Been thanked: 1852 times
Different issue with AWD cars as they can leak on the axle seals between the RH drive axle and the angle gear. FWD not a big issue as per Erik.
BobbyC777
Post by BobbyC777 »
When replacing the passenger side (right) axle must one be careful when inserting the axle into the differential housing not to displace the axle seal? Or is this not really an issue? Thanks!
Post by cn90 »
Not an issues bc the axle goes into a "cup"...
The axle seal circles around the cup.
I made a sketch in that DIY...
BobbyC777
Post by BobbyC777 »
@cn90 - I had not scrolled down far enough in your DYI so missed a bunch of stuff on my earlier pass. Great diagrams there - thanks!
