I have a cheap HF press, and I wish I've got a better one. Used it so many times, it deserves to be of a better quality. Latest use case is bending metal for fabrication, bought a brake attachment for that.abscate wrote: 06 May 2026, 03:50 I mounted my vice and a cheap drill press guide on my press so that it serves three functions. That’s the magic number for anything in my life , it has to have three functions or more to buy.
$150 press, 10 uses, $15 per use but each use saves me hours of pounding and damaging stuff with hammers.
Last time it was pushing a stuck axle from a bad hub. 5 minutes
Front ball joint tool - worth having or not? - 06 V70/XC70 Topic is solved
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 33 times
- Been thanked: 82 times
Usually it's discouraged to heat aluminium suspension parts because you can alter the metal structure without realizing it.scot850 wrote: 05 May 2026, 08:32 Has nobody used heat on the surrounds of the ball joint to help get it loose? I seem to recall doing that one time.
I know that people will start saying "I've been doing that for 20 years and nothing ever happened", but it's better not to do it if it can be avoided.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
- Has thanked: 2196 times
- Been thanked: 1850 times
I agree, but the issue is if you do extended heating of an aluminum part. I have that concern with powder coating aluminum wheels. They definitely get softer. In this case you are only heating it for a short time to break the corrosion between the metals.
Your point is noted though!
vtl
The cheapest 12 Chinese tons Harbor Freight press had no problems pressing those out, with all the corrosion. If anything, I would advise directing heat towards metal shell of the bushing, which you can do with inductive heater. Heating the whole control arm with propane torch is counter-productive and alters metallurgy, as already said.scot850 wrote: 06 May 2026, 10:22 I agree, but the issue is if you do extended heating of an aluminum part. I have that concern with powder coating aluminum wheels. They definitely get softer. In this case you are only heating it for a short time to break the corrosion between the metals.
Don't heat the whole arm, just the area around the ball joint. Anyway, I now have a tool for this!
There a quite a few presses for sale on FBM and other mediums locally should I ever wish to invest in one.
Thanks for help guys. Oh, an induction tool would be nice. Anyone tried one of those cheap ones that worked?
vtl
Cheap enough? https://www.amazon.com/dp/B0DD7HY3ZBscot850 wrote: 06 May 2026, 10:32 Oh, an induction tool would be nice. Anyone tried one of those cheap ones that worked?
I use it mainly on my 5ish years Toyotas, which have corrosion problems unheard of in P2 Volvo world. The toughest job was pressing the rusted bolt out of the leaf spring bushing without damaging the rubber. A few cycles of heating with this inductive heater and cooling with PB Blaster, and that b*****d gave up and was successfully pressed out.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Do people leave the knuckle on for BJ removal/installation? I always just removed the full knuckle and did it on the bench. Not enough leverage with the unit on jack stands.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
vtl
On the bench (garage floor) always.br0dy519 wrote: 06 May 2026, 12:47 Do people leave the knuckle on for BJ removal/installation? I always just removed the full knuckle and did it on the bench. Not enough leverage with the unit on jack stands.
- Been thanked: 4063 times
You break a lot fewer fasteners working on the bench, making sure bits are square and tools are on correctly.
One stripped head and all the time “saved” on hacks is taken back by the Tool Devil. On the bench, he is vanquished and banished back to the chain muffler shops
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I’ve always removed the full knuckle, plus that way when I give up and take it to a shop it’s a whole lot easier to carry in and let them do the work … for pretty cheap.br0dy519 wrote: 06 May 2026, 12:47 Do people leave the knuckle on for BJ removal/installation? I always just removed the full knuckle and did it on the bench. Not enough leverage with the unit on jack stands.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 12 Replies
- 1939 Views
Last post by erikv11
- 11 Replies
- 3156 Views
Last post by theWIFES_S70
- 4192 Views
Last post by ndphotonl
- 18 Replies
- 9547 Views
Last post by Krons
- 1855 Views
Last post by precopster
