Vibration/Grinding when turning left Topic is solved
Has thanked: 2196 times
Been thanked: 1850 times
Dust shields are always worth checking. They corrode around the 3 mounting bolts and then break free. Tends to cause a rattle. Usually a large washer under the head of the bolt will fix that.
rolsen11
Year and Model: 00 V70, 04 S60R
Has thanked: 56 times
Been thanked: 58 times
Post by rolsen11 »
I think I might have found the potential cause for the problem. I feel a little stupid for not thinking of this as a cause, wheel alignment! I already knew the alignment wasn't good since the steering wheel has been off to the left since I bought the car, but I just realized that the front wheels are toed out away from each other slightly. This is the exact same alignment problem I had on my V70 when I bought it, although that car didn't make any noise when steering. I'm still going to get the other front wheel bearing replaced next week and immediately after that I will be taking it in for alignment. Hopefully that will solve it.
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
Let us know if that is the solution. It would be great is it is!
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
If you already need alignment. Make sure your tie rods are in tiptop shape and balljoints with control arms as well. Alignment is about 120-170 depending on the area, so better pay once then to have to do it after another component fails shortly after.
rolsen11
Post by rolsen11 »
It WAS the front left wheel bearing! With the bearing connected to the CV axle and the wheel it was hard to tell if it was bad or not but when I disconnected those things and freely spun the bearing with my hand, it sounded absolutely terrible. New SKF bearings installed on the front and the car is now significantly nicer to drive. I had a big smile on my face on the way back home finally getting to experience what this car is actually like. I love it! Next up is to get the alignment done.
