Well, the AC started acting up today. The Relay was ON, but the Compressor was not turning.
A few minutes ago, I connected a Test Light to the wire, right at the Compressor. I used a long wire to make the Test Light visible from the Driver's Seat while driving down the Road.
Tomorrow I should be able to tell if the Problem is from the Power disappearing, or if it has to do with the Compressor itself. The Schematic shows that a Pressure Switch is built into the Compressor. Conceivably, this Pressure Switch could be "shutting Off" the Compressor.
I'll let you know what I find.
Rob3
'99 V70 AC Problem
Well, I did it. Took me 6.5 hours. My AC Compressor Clutch is now gapped at .3 mm and is working fine.
I removed the thickest Shim and reinstalled the Clutch plate. It measured at .49 mm. I removed the next thickest Shim (leaving only the thinest Shim) and reinstalled. Now measures just a hair over .3 mm. I guess my Shims are thinner than the ones in the pdf.
My Bolt Heads for the Compressor Mounts were on the Radiator side of the Compressor. The pdf I read said they would be on the Firewall side.
Not much to add except, Thanks to all who've contributed. This knowledge saved me a lot of money.
Rob3
Rob3
- Year and Model: Many Volvos
- Been thanked: 76 times
A ton of work but one heck of a $$ savings. Thanks for letting us know what worked and what didn't. I'm sure it will help others!
- 2598 Views
- 1600 Views
- 12 Replies
- 3432 Views
Last post by Jaguar xjs
- 19 Replies
- 7471 Views
- 15 Replies
- 7864 Views
Last post by tango_1000
