Inner and Outer Tierod End replacement tutorial
This topic is in the MVS Volvo Repair Database » Inner/Outer Tie Rods DIY - S70, V70, 850, XC70
figmentj13
Year and Model: 2002 XC70
Post by figmentj13 »
You can buy them from IPD or eEuroparts or just search the "part number"+ "Volvo" on google and you will find it.
Warren561 wrote:I am trying to source the boots in order to do this repair. I need the SMI boots (Volvo P/N 9191409). It appears that the only name-brand aftermarket for these is "KARLYN." Has anyone ever tried the KARLYN brand boots? Are they any good?
I'm seeing a 2 pack of KARLYN for about $30 on eBay vs $46 each for Genuine Volvo at TASCA.
RIP: 2000 V70 SE <- Rear end while parked. :-(
Warren561
Year and Model: 2000 S70 5sp Auto
Post by Warren561 »
figmentj13 wrote:You can buy them from IPD or eEuroparts or just search the "part number"+ "Volvo" on google and you will find it.
Thanks for the tip. I actually just found Lemforders on Amazon.
https://www.amazon.com/gp/product/B001G6 ... UTF8&psc=1
P/N is W0133-1635686-LEM
It's pretty neat that Amazon even notes the SMI rack identification.
Code: Select all
Notes: SMI Brand Steering Service Plate Marking #5 This steering rod is referenced to vehicles with the product plate code mark of "5". The product plate is located on the driver's side wheel well. Check the 5th line of the plate for the last digit to the right of the divider to look for the correct steering gear code mark.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Does the inner tie rod ball joint come with a grease pack or is it pre-greased with just a light coat?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
dosbricks
Been thanked: 4 times
Post by dosbricks »
Question: Would it help any to turn the wheel to extend the rack toward the side you are working on just a couple of inches so as to get better access for the pipe wrench to get a bite? It would have to be turned back to center to wrestle with getting the rear end of the boot on to rack (which looks like more fun than a barrel of monkeys :? ).
Thanks, MIJ, for posting this. Our 70 needs this work and I have been waffling about whether to attempt it along with control arms/ball joints and outer CV boots--all of which would probably be my undoing. :cry:
dos
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
The inner's I got were ready for install, completely packed. Though I have a inner tie rod tool I used a pipe wrench for removal. easy and quick. I used the Karlyn boots with the supplied zip ties. I greased the rack side of the boot so it would slide onto the rack.
mecheng
Post by mecheng »
Is the ball joint sealed, i can't tell from the pics
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
dosbricks wrote:Question: Would it help any to turn the wheel to extend the rack toward the side you are working on just a couple of inches so as to get better access for the pipe wrench to get a bite? It would have to be turned back to center to wrestle with getting the rear end of the boot on to rack (which looks like more fun than a barrel of monkeys :? ).
dos
Working on inner tie-rod will damage steering rack if you are a first timer - failure would follow. Hammering, heating, excessive force, wrong tool is not recommended.
Read this post https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=54721
Save all the money you are spending on the tie-rods, and purchase a rebuild SMI rack. It will come with inner and outer tie-rod, boot, etc. Replace the entire steering rack. You will save and get ahead.
rebuild steering rack
xHeart
Post by xHeart »
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
@xHeart
Do you have a link for the place that sells these rebuilt racks? Wondering what they cost.
Well, most people seem to manage it with a pipe wrench, I didn't. I'm glad I invested in the proper tool, was a breeze with it (and you can also use it without an impact gun no problem) and cheaper than letting a shop do it. (I think it was this one or similar http://www.amazon.de/NBS-Werkzeuge-Spur ... B009K8R6JG )
850 T5-R '95 auto Image
xHeart
Post by xHeart »
hausmeister wrote:@xHeart
Noticed that you are in Austria.
In US, our MVS erikv11 recommended Jorgen Auto http://www.jorgenauto.com/rack-pinion/volvo.html.
I installed TRW, helpful tech.
